#include file in a subdirectory
I'm using the C166 compiler. I'm trying to restructure a project, and wanted to put serveral related files in a subdirectory, say "thing". We have several source and header files that look like
./thing1_this.c
./thing1_this.h
./thing1_that.c
./thing1_that.h
./thing2_this.c
./thing2_this.h
I want to create subdirectories
thing1/
and and
thing2/
and to move these to
thing1/
  thing1/this.c
  thing1/this.h
  thing1/that.h
  thing1/that.h
thing2/
  thing2/this.c
  thing2/that.h
Then the files which include the header files would go from
#include "thing1_this.h"
#include "thing1_that.h"
#include "thing2_this.h"
to this:
#include "thing1/this.h"
#include "thing1/that.h"
#include "thing2/this.h"
The compiler can't find the header files in this configuration. I've tried other path separators ('\\', '\'), but to no avail. I have './' explicitely in my
INCDIR(...)
directive.
I've also made sure that the directory name is within DOS filename limits.
The description of the include search method in the manual was very sparse, and I could find nothing on the forums how this might be done or whether the compiler could do this at all.
Is this a limitation of the compiler that the preprocessor doesn't know how to include file paths? Or is their some syntax I haven't tried?
If I must I can put
./thing1
and
./thing2
in my
INCDIR(...)
directive and name this files like this:
thing1/
  thing1/thing1_this.c
  thing1/thing1_this.h
  thing1/thing1_that.h
thing2/
  thing2/thing2_this.c
  thing2/thing2_that.h
but my original setup is better, and I'd like to do that if I can.
Thanks Much.
  • Note that the file "thing1/this.c" would not manage to do
    with an include path of "." since it would look for a header file relative to itself (i.e. the thing1 directory) which would be "thing1/thing1/this.h" in relation to the root of the project.
    So all files in "thing1" would need to just look for "this.h".
    And if they need include files from the neighbour directory then they would need "../thing2/this.h"
    If you instead in the include path specify the absolute path of your project root, then it will be possible for any file in the project to try to include "thing1/this.h".
    Using the absolute path worked, so thanks.
    The manual says that files included with #include "..." are searched in the following folders in order:
    The current folder.
    The source file folder.
    Paths specified by the INCDIR directive.
    Paths specified by the C166INC environment variable.
    So (unless that's wrong) I'm still not sure why it didn't find them, even without adding anything to the INCDIR directive.
    Thanks Much.
  • I'm not sure what they mean with "current folder".
    Different compilers have different rules for exactly how they process #include "".
    But it is quite common that they look relative to the source file directory.
    While it's not so common that they look relative to the project root directory.
    In case you shorten the name of your header files so you get "thing1/this.h" and "thing2/this.h" then you have two files with the same name. This can be a serious issue if you include "this.h" and expect the path to find the file, since the search path will have one of the directories before the other so one file will be incorrectly found. Always specifying the "thing1/" and "thing2/" prefix in the include and searching relative the project root removes this problem.
    Another issue to think about is having multiple source directories with "this.c" - since that will produce multiple "this.o" or "this.obj". If the compiler tries to store all object files in a common output directory then bad things will happen.
    I had assumed that they meant "Current working directory of the compiler process". But it seems not.
    Yes. It's not an issue, though, if they are always included as "thing1/this.h", etc.
    That's true. Of course, these were just example file names for the sake of posing the question. Ideally, the output directory hierarchy would mirror your source file directory structure, so that "src/thing1/this.c" would compile to "output/thing1/this.obj", and so on.
  • "Ideally, the output directory hierarchy would mirror your source file directory structure, so that "src/thing1/this.c" would compile to "output/thing1/this.obj", and so on."
    Exactly. But I don't use the C166 tools so I don't know - it's just something to be careful with as it may create problems.
