Conflicting compiler for startup_stm32f070xb.s file
I am new at KEIL. Planning to work in this environment
IDE-Version:
µVision V5.21.1.0
Copyright (C) 2016 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers:
Toolchain: MDK-Lite Version: 5.21a
Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin
C Compiler: Armcc.exe V5.06 update 3 (build 300)
Assembler: Armasm.exe V5.06 update 3 (build 300)
Linker/Locator: ArmLink.exe V5.06 update 3 (build 300)
Library Manager: ArmAr.exe V5.06 update 3 (build 300)
Hex Converter: FromElf.exe V5.06 update 3 (build 300)
CPU DLL: SARMCM3.DLL V5.21a
Dialog DLL: DCM.DLL V1.13.8.0
Target DLL: UL2CM3.DLL V1.158.5.0
Dialog DLL: TCM.DLL V1.14.14.0
I was using GNU Tools ARM Embedded(5.4 2016q3) in Coocox v.2 beta IDE environment.
The compiler gives the error such as,
\common\Drivers\CMSIS\Device\ST\STM32F0xx\Source\Templates\gcc does not exist.
In this file location startup_stm32f070xb.s file is already exists !
Whats wrong with here? Do I need to update version of anything?
Help me please
Help me to open or make a new project in MDK-Lite
0
