I have been trying to program my stm32f429i discovery board as a Mass Storage Class Host for Read/Write operations in a USB Pendrive. I'm using Keil uv5 compiler. When i select the appropriate packs and compile. It shows the following error:
USBH_FS_STM32F4xx.c(877): error: #20: identifier "ARM_USBH_PIPE_HANDLE" is undefined
USBH_FS_STM32F4xx.c(354): error: #20: identifier "ARM_USBH_SignalPipeEvent_t" is undefined
You probably don't have the latest CMSIS pack V4.2.0 installed. You can launch the pack installer and add the mentioned pack.
Thank you! The problem has been solved.
