How to use negativ values with the configuration wizard?
If I try:
//<<< Use Configuration Wizard in Context Menu >>> // <h> runtime time range // <o> motor runtime in temperature range 1 upper bound [°C] <-128 - 127> #define DOPD_RUNTIME_TEMPERATURE_RANGE_1_LIMIT ((SB__8) 0 ) // </h>
I will always get an error message from the wizard about the '-' in front of 128.
It might not support it, since it was developed for configurations of unsigned special function registers.
But you can always make use of an offset.
