debbuging on shared drive/ trace tmp file path
hi, and thanks per advance,
I work on Keil uvision5 /cortex-M with ulink pro.
all my project are on a network shared drive.
all is fine except that all the trace files (*.tdi *.tds ...) are saved in a temporary folder (something like {XXX-YYZ ... }) in the project directory and not in the tmp directory set with the TMP windows environement variable.
this make debuging features are very slow due to network acces to huge file.
Is anyone had find a way to set TMP folder in order to set this debugger files in the local TMP folder?
thanks to all.
nicolas.
0
