Hello, my Problem is I can't install a Software pack. The Error is when I try it from the uVison Pack Installer: File download failed: http://... Reason: Cannot write destination file
When I manually dowload it and try to install, for example Keil.LPC1700_DFP.2.0.0.pack The Error is: Cannot copy PDSC file to ".Dowload" folder.
I use Windows 8.1 64 Bit and uVision V5.12
thanks for the help.
I thing ptoblem with access right for folder Keil.
Hello Fabian,
into which folder have you installed uVision? If it is in "Program Files", this is a permission issue. Please install it in a directory that you can control with the normal user account.
Kind regards,
Christopher
