I have Source code in IAR compiler. I would like to convert them and run on Keil, but i don't know how to do this. If there is a way can anyone give example of how to do it or some instruction to do this.
Step #1
Ensure that the code you have for the IAR project is for a processor that Keil supports.
Do you have competence in either tool chain?
Create an equivalent project framework in Keil, bringing in all of your source files, set include paths and defines. Compile the C files and determine which have errors, and issues specific to IAR unique features.
.S files may be more problematic as the formatting/controls are different. You should review the board/example directories for chip/architecture appropriate startup.s files, and merge/port in any assembler functions unique to your project implementation.
.LIB/.A files may also be a problem, you'll want to recreate them for the Keil chain, or obtain Keil versions from the vendors.
