Hello, I have a problem with the compiler optimizing away a volatile variable, and as a result generating an endless loop. My program is too big to show here, but I created an example main.cpp file which compiles the same way (with the same issue). It is quit possible the issue is not in the compiler, so I'm asking for help. Here:
uVision V5.10.0.2 Armcc.exe V5.04.0.49
cmdline (options) = -c --cpu Cortex-M4.fp -g -O1 -Otime --apcs=interwork --asm --interleave --asm_dir ".\\" -I C:\Keil_v5\ARM\RV31\INC -I C:\Keil_v5\ARM\PACK\ARM\CMSIS\3.20.4\CMSIS\Include -I C:\Keil_v5\ARM\PACK\Keil\ARMCortex_DFP\0.0.1\Device\Include -o "*.o" --list_dir ".\\" --list --omf_browse "*.crf" --depend "*.d"
code (file=main.cpp):
#include "stdio.h" typedef int BOOL; class Event { volatile BOOL w; public: Event() { w=0;} void SetEvent() { w=1;} void SetEventFromInterrupt() { w=1;} void ResetEvent() { w=0;} BOOL CheckEvent() { return w;} }; void SetupIrqEvent(Event *event); void TestEvent() { Event event; SetupIrqEvent(&event); // problematic area - code (when -O1 or higher) will not r ead from memory (stack) // wait for the event while(!event.CheckEvent()) ; SetupIrqEvent(NULL); } Event *irqEvent=NULL; void SetupIrqEvent(Event *event) { irqEvent=event; } extern "C" void MyIrqHandler() { if(irqEvent!=NULL) { irqEvent->SetEventFromInterrupt(); } }
Here is the listing I'm getting for TestEvent function:
_Z9TestEventv PROC ; TestEvent() ;;;15 ;;;16 void TestEvent() 000006 b508 PUSH {r3,lr} 000008 2000 MOVS r0,#0 00000a 9000 STR r0,[sp,#0] ;;;17 { ;;;18 Event event; ;;;19 SetupIrqEvent(&event); 00000c 4668 MOV r0,sp 00000e f7fffffe BL _Z13SetupIrqEventP5Event ; SetupIrqEvent(Event*) 000012 9800 LDR r0,[sp,#0] |L1.20| 000014 2800 CMP r0,#0 ;;;20 while(!event.CheckEvent()) ; 000016 d0fd BEQ |L1.20| ; jump back to comparison, skip reloading ;;;21 SetupIrqEvent(NULL); 000018 2000 MOVS r0,#0 00001a f7fffffe BL _Z13SetupIrqEventP5Event ; SetupIrqEvent(Event*) ;;;22 } 00001e bd08 POP {r3,pc} ;;;23 ENDP
As you can see event.CheckEvent() gets inlined to a comparison, without reading the word each time from the memory (even though w is declared volatile).
Any ideas how can I fix this ? This is part of a lot of legacy code I have to deal with, and "just be careful and don't use volatile in local variables or classes which might have local instances" is not really an option.
