Renew and reconnect a new TCP connection
Hello
I configure my ARM as an Ethernet server and I open a desire port via tcp_listen and each loop I send data (before that I check "tcp_check_send () " and then start to transmit).my problem is when I close the first connection I can't connect again to this server.
net_initialize();
tcp_soc = tcp_get_socket (TCP_TYPE_SERVER | TCP_TYPE_KEEP_ALIVE, 0, 100, tcp_callback); if (tcp_soc >= 0) {tcp_listen (tcp_soc, 20000);} s=0; while (1) { net_main (); if (tcp_check_send (tcp_soc)){ sendbuf = tcp_get_buf (sizeof(msg)); memcpy (sendbuf, msg, sizeof(msg)); tcp_send (tcp_soc, sendbuf, sizeof(msg)); } }
I check different approaches but I can't.how can renew my connection and waiting for new client?
an other problem is when I close the connection via my pc (as a client) I see my arm still sends packages to my pc(because it's Ethernet led blink such as before) .why doesn't tcp_check_send detect connection is close?
  • Dear Chen Tang
    Thank you for your response.
    As I tested before when I remove "TCP_TYPE_KEEP_ALIVE" it causes the same problem
    Yes I have been read a lot about TCP/IP three handshaking but I need a function in Keil that return TCP/IP statues when it fails or our connection interrupt suddenly.
    However as I told before when I disconnect from my board my server sends data after 10 seconds and it seems keil's function can't detect this situation.Am I right?
    How can renew my connection ?
  • Dear Chen Tang
