When "Build" button is pressed the code builds successfully and also automatically downloaded to the attached board and automatically move to the debug mode.
I just want to know what/where setting needs to be changed to STOP this process? I just want when "build" button is pressed the code should only BUILD.
Previously I was using MDK V5.11 and now I installed MDK V5.18 and also created a new project...& the problem is solved
