Sending data from Stmf103 microcontroller using UART to serial port (using c)
Hello everyone,
I am quite new to microcontroller so i need to know how can i send data from Stmf103 microcontroller using UART (using c). I just start learning about this so at 1st i just wanted to send a simple "hello world" using UART from Stmf103rbt6 microprocesssor to a server via wifi. Is there any library for this that i can use? if you give me a head start that would be really helpful.
  • Being non-specific about a board, uart and pins, I picked on for you. This uses the v3.5.0 Standard Peripheral Library.
    // STM32 Keil printf USART2 (Tx PA.2, Rx PA.3) STM32F103RB NUCLEO - sourcer32@gmail.com
    #include "stm32f10x.h"
    #include <stdio.h>
    #include <stdlib.h>
    void USART2_Configuration(void)
      USART_InitTypeDef USART_InitStructure;
      GPIO_InitTypeDef GPIO_InitStructure;
      /* Enable GPIO and USART2 clock */
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
      /* Configure USART Tx as alternate function push-pull */
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
      GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
      GPIO_Init(GPIOA, &GPIO_InitStructure);
      /* Configure USART Rx as input floating */
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
      /* USARTx configured as follow:
            - BaudRate = 9600 baud
            - Word Length = 8 Bits
            - One Stop Bit
            - No parity
            - Hardware flow control disabled (RTS and CTS signals)
            - Receive and transmit enabled
      USART_InitStructure.USART_BaudRate = 9600;
      USART_InitStructure.USART_WordLength = USART_WordLength_8b;
      USART_InitStructure.USART_StopBits = USART_StopBits_1;
      USART_InitStructure.USART_Parity = USART_Parity_No;
      USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
      USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
      /* USART configuration */
      USART_Init(USART2, &USART_InitStructure);
      /* Enable USART */
      USART_Cmd(USART2, ENABLE);
    void OutString(char *s)
      while(*s)
        while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET); // Wait for Empty
        USART_SendData(USART2, *s++); // Send Char
    int main(void)
      RCC_ClocksTypeDef RCC_Clocks;
      /*!< At this stage the microcontroller clock setting is already configured,
           this is done through SystemInit() function which is called from startup
           file (startup_stm32f10x_xx.s) before to branch to application main.
           To reconfigure the default setting of SystemInit() function, refer to
           system_stm32f10x.c file
      RCC_GetClocksFreq(&RCC_Clocks);
      USART2_Configuration();
      OutString("Welcome to Nucleo F103RB\r\n");
      printf("Hello World!\n");
      printf("Running at %d MHz\n", RCC_Clocks.SYSCLK_Frequency / 1000000);
      while(1); // Don't want to exit
    // Hosting of stdio functionality through USART2
    #include <rt_misc.h>
    #pragma import(__use_no_semihosting_swi)
    struct __FILE { int handle; /* Add whatever you need here */ };
    FILE __stdout;
    FILE __stdin;
    int fputc(int ch, FILE *f)
      USART_SendData(USART2, ch);
      return(ch);
    int fgetc(FILE *f)
      char ch;
      while(USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET);
      ch = USART_ReceiveData(USART2);
      return((int)ch);
    int ferror(FILE *f)
      /* Your implementation of ferror */
      return EOF;
    void _ttywrch(int ch)
    void _sys_exit(int return_code)
    label:  goto label;  /* endless loop */
    #ifdef  USE_FULL_ASSERT
      * @brief  Reports the name of the source file and the source line number
      *         where the assert_param error has occurred.
      * @param  file: pointer to the source file name
      * @param  line: assert_param error line source number
      * @retval None
    void assert_failed(uint8_t* file, uint32_t line)
      /* User can add his own implementation to report the file name and line number,
         ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
      /* Infinite loop */
      while (1)
    #endif
  • Hallo I am using the STM32F103R8T6, Want to transfer one character by UASRT. I write this code but I got this error which I can not solve can you help me how can I solve this problem .
    Error: Flash Download failed - Could not load file 'D:\STM32F10_Fixed\STM32F10\Project\Objects\stm32f103r8t6_.axf'
    /* Includes ------------------------------------------------------------------*/
    #include "main.h"
    #include "stm32f10x_usart.h"
    void RCC_Configuration(void);
    void Delay(__IO uint32_t nCount);
    void GPIO_Configuration(void);
    void USART1_Configuration(void);
    int main(void)
    { RCC_Configuration(); GPIO_Configuration(); USART1_Configuration(); ////////////////
    //USART_Init();
    /////////////////////USART_Init(USE_USART1);
    while (1) {
    while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
    USART_SendData(USART1, 'X');
    /* set pin */ GPIO_ResetBits(GPIOC, GPIO_Pin_4); ////////////////////// ooo
    //////// /* Insert delay */ Delay(1000);
    /// USART_SendData(USART1, 'T');
    ////// if ( GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1)) ///////////////////////+
    ////// GPIO_ResetBits(GPIOC, GPIO_Pin_4); ///////////////////////// A 1
    ////////////// Delay(100);
    ////// else //////////////////////////////////////////////////////////////// +
    ////// { ////////////////////////////////////////////////////////////// + GPIO_SetBits(GPIOC, GPIO_Pin_4); ///////////////////////////////////// Delay(1000);
    USART_InitTypeDef USART_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIO and USART1 clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); /* Configure USART Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* Configure USART Rx as input floating */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* USARTx configured as follow: - BaudRate = 9600 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    /* USART configuration */ USART_Init(USART1, &USART_InitStructure);
    /* Enable USART */ USART_Cmd(USART1, ENABLE);
    ////////////////////////////////////////////// void Delay(__IO uint32_t num) { __IO uint32_t index = 0;
    /* default system clock is 72MHz */ for(index = (72000 * num); index != 0; index--) { }
    { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); ////////////////////////////A
    { GPIO_InitTypeDef GPIO_InitStructure;
    //GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1);//
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //////////////////////////////////////////// 1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOC, &GPIO_InitStructure); //////////////////////////////////// C
    /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */
    { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    /* Infinite loop */ while (1) { }
    } #endif
    /******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
