Help with ARM7 LPC2138
Good Morning,
I made a code here and it was working normally, but to implement a new function run into this error .. seems to be memory size or something , someone knows or can help me ? The program I use to debug is the IAR Embedded Workbench IDE.
The error is the following:
Error[e16]: Segment CODE (size: 0x4a30 align: 0x2) is too long for segment definition. At least 0xb50 more bytes needed. The problem occurred while
processing the segment placement command "-Z(CODE)CODE=40-3FFF", where at the moment of placement the available memory ranges were
"CODE:120-3fff"
Reserved ranges relevant to this placement:
40-11f ICODE
120-3fff CODE
Thanks, Thiago Brandão.
0
