I am having some trouble getting the UART module on my 8051 to transmit. The TXD pin shares usage with the LCD and the RXD shares usage with the OE pin of a latch.
Here is what I am doing. I am using a Logic Analyzer to verify that I am transmitting.
...Print to LCD (uses TXD) mov SCON, #50h mov TMOD, #20h clr TCLK clr RCLK ;I do a case for baud one ex is anl PCON, #7Fh mov TL1, #98h mov TH1, #98h setb REN clr TI clr RI setb TR1 mov A, DPH call convert_to_ascii call get_parity transmita: mov SBUF, A jnb TI, $ clr TI jmp transmita
