According to http://www.keil.com/appnotes/files/apnt_266.pdf ST going on STM32 Cube tighter integration with MDK-ARM, and support CMSIS-API Driver 2.02. You do not know when it will be released version 2 with support for CMSIS-API Driver 2.02? It will be the integration so far that will go in the next STM32 Cube use and RTX and other midleware components contained in the Keil MDK-ARM Pro?
