c code for AT89S52
my c code is as shown below
but when i compile in keil compailer it will show as
c(4): warning C318: can't open file 'DELAY.H'
c(21): warning C206: 'delay_ms': missing function-prototype
(21): error C267: 'delay_ms': requires ANSI-style prototype
Target not created
please someone help me to correct this
#include<stdio.h>
#include<math.h>
#include<reg51.h>
#include"DELAY.H"
# define DATA P1
void msdelay(unsigned int);
sbit e=P3^7;
sbit rw=P3^6;
sbit rs=P3^5;
sbit s1=P2^0;
sbit s2=P2^1;
sbit s3=P2^2;
sbit relay=P0^6;
sbit s4=P2^3;
void mov_stepper(unsigned char dir,unsigned char rot)
{ while(rot>0)
{ if(dir=='c')
{ P0=0X08;
delay_ms(5);
P0=0X04;
ms_delay(5);
P0=0X02;
ms_delay(5);
P0=0X01;
ms_delay(5);
} if(dir=='a')
{ P0=0X01;
ms_delay(5);
P0=0X02;
ms_delay(5);
P0=0X04;
ms_delay(5);
P0=0X08;
ms_delay(5);
} rot--;
void lcd_cmd(unsigned char temp)
{ DATA=temp;
rs=0;
rw=0;
e=1;
ms_delay(5);
e=0;
ms_delay(5);
} void lcd_data(unsigned char temp)
{ DATA=temp;
rs=1;
rw=0;
e=1;
ms_delay(5);
e=0;
ms_delay(5);
} void lcd_init()
{ lcd_cmd(0x38);
lcd_cmd(0x06);
lcd_cmd(0x0e);
lcd_cmd(0x01);
lcd_cmd(0x80);
} void lcd_puts(unsigned char *s)
{ lcd_init();
while(*s!='\0')
{ lcd_data(*s);
s++;
void main()
{ P0=0X00;
P2=0X00;
while(1)
{ if(s1==1)
{ mov_stepper('c',3);
lcd_puts("FIELD A");
while(s1!=0)
{ relay=1;
} relay=0;
mov_stepper('a',3);
lcd_puts("MONITORING");
} if(s2==1)
{ mov_stepper('c',6);
lcd_puts("FIELD B");
while(s2!=0)
{ relay=1;
} relay=0;
mov_stepper('a',6);
} if(s3==1)
{ mov_stepper('a',9);
lcd_puts("FIELD C");
while(s3!=0)
{ relay=1;
} relay=0;
mov_stepper('c',9);
} if(s4==1)
{ lcd_puts("FIELD D");
while(s4!=0)
{ relay=1;
} relay=0;
} lcd_puts("MONITORING");
  • follow the posting instructions and, maybe someone can figure out your problem
    anyhow based on the errors I doubt it is "my c code", the errors are typical for a download from the web
  • Rule #1 when you get compilation errors: Try to understand the first error you get.
    "c(4): warning C318: can't open file 'DELAY.H'"
    So - why should _we_ try to help you with this? If this is _your_ code, then _you_ already have written a "delay.h" file.
    If this is _not_ your code, then maybe you should look for a "delay.h" file in the same location you found all the other code.
    You need to improve your C skills a bit more before you try to sit down and take the next test at school - your teacher really expect you to understand the meaning of include files. And the result of trying to include a file that the compiler can't locate...
  • I got the same code. You can fix it to make a file "DELAY.H" and put in the line
    void msdelay ( unsigned int tadger )
    { if ( tadger != 0 ) msdelay ( tadger-- );
  • And that would be a high score in bad content of the file.
    Why place the implementation in the header file, when the original code was written with the intention of having the delay in a separate source file?
    Secondly - the OP has significant issues with what name to use for the delay function. And you selected to suggest a third alternative name.
    Thirdly - why implement a recursive delay?
  • sir actually i dont know to make c code. I am mechanical student i just copied the code for my project
  • so just me gave you any code. and some mr person complained about that.
    a small change and you can compile it. it is not best but it can help u. plz try.
    make a file "DELAY.H" and typing in the lines
    #define delay_ms(gogo) mydelay(gogo)
    #define msdelay(gogo) mydelay(gogo)
    #define ms_delay(gogo) mydelay(gogo)
    void mydelay ( unsigned int tadger )
    { while ( tadger > 0 ) { unsigned long i; for ( i = 0 ; i < 65327 ; i = i + 1 ) ; }
  • fix a very little error
    { while ( tadger > 0 ) { unsigned long i; tadger -= tadger; for ( i = 0 ; i < 65327 ; i = i + 1 ) ; }
  • code is very complicated. easy to get bugs :-(
    { while ( tadger > 0 ) { unsigned long i; tadger -= 1; for ( i = 0 ; i < 65327 ; i = i + 1 ) ; }
  • Thank you very much sir.It is working
    are you saying that they give you a project that you have no idea how to handle, even if you had paid attention in class?
  • I'd probably want to pay for such an education with photocopied bank notes.
