Hi everyone,
I'm currently developping an app with STM32F4 - discovery board. I'm sampling some sounds with the microphone and the DMA, and i analize it with signal processing.
I'm using the CMSIS arm_lms_f32 function
void arm_lms_f32 ( const arm_lms_instance_f32 * S, float32_t * pSrc, float32_t * pRef, float32_t * pOut, float32_t * pErr, uint32_t blockSize )
All my buffers PSrc,PRef... are initialized with float32_t PSrc[blockSize ];
The instance structure is initialized with
arm_lms_init_f32(&S, NUM_TAPS, firCoeffs32, firStateF32, beta, blockSize );
The code works fine and realize the sound processing i want. But when i increase the "blockSize" the programm counter jump in hard_fault after calling arm_lms_f32.
I tried to look at the arm_lms_f32 code : github.com/.../arm_lms_f32.c
Tried to look at my memory and increase my stack value. But nothing changes, for a blocksize > 8 a hardfault interrupt is generated.
Does someone know why ? Thanks a lot for your help.
