Network Middleware TCP timing
Dear all,
We've switched from the previous network middleware to version 7.0.0beta.
In the new middleware two threads run (1x Core-Thread and 1x ETH-Thread)
Now I want to send out TCP messages at 100Hz.
The network threads seem to run at about 40Hz (25ms)
But I want them to run faster to service my 100Hz message-creation-task. Is this possible?
Or are there other ways of solving this issue?
Kind regards,
Gerrit
  • Contacted Keil support and got this reply:
    This bad performance using netTCP_Send() is probably due to a bug we found recently in our MW Network v7.0, which can be summarized as follows:
    These socket send functions do not wakeup the network core thread to immediately process the send request. Instead these send requests are processed at the next tick, which causes a bad send performance.
    Thought I post this in case other people stumbled upon the same performance issue.
    They provided me with a patched library.
    This patch will be included in v7.1 which will probably launch end of March 2016
    In the meantime contact Keil for the patched libraries.
    Kind regards,
    Gerrit
  • Thanks Gerrit for sharing this info!
    In most cases this issue won't be noticeable, unless you have to send tcp packets very frequently. But it is good that Keil has fixed this issue.
