ARM:LPC11E68JBD100
Now I use keil uVision 5.16 to create nxp LPC11E68JBD100 project,found startup file system_LPC11E6x.c has a error tip at #include "LPC11E6x.h",the tip is: " error in include (cmsis_armcc.h):expected or identifier '(‘", if I change #include "LPC11E6x.h" to #include "LPC11Exx.h",There is no tip. why ?
thanks!
Jansen
system_LPC11E6x.c:
/**************************************************************************//** * @file system_LPC11E6x.c * @brief CMSIS Cortex-M3 Device System Source File for * NXP LPC11E6x Device Series * @version V1.00 * @date 16. June 2014 * * @note * Copyright (C) 2014 ARM Limited. All rights reserved. * * @par * ARM Limited (ARM) is supplying this software for use with Cortex-M * processor based microcontrollers. This file can be freely distributed * within development tools that are supporting such ARM based processors. * * @par * THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED * OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. * ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER. * ******************************************************************************/
#include <stdint.h> error tip #include "LPC11E6x.h"
/* //-------- <<< Use Configuration Wizard in Context Menu >>> ------------------ */
/*- SystemCoreClock Configuration -------------------------------------------*/ // <e0> SystemCoreClock Configuration #define CLOCK_SETUP 1 // The rest has being canceled
If the startup code looks like the mess you posted, then it's really not fit for purpose.
Are you sure you posted it using the suggested method?
