Need to convert arm_bitreversal2.S to C code
I am working on porting FFT functionality from CMSIS DSP library to another architecture.
Unfortunate I faced with problem that arm_bitreversal_32 function is implemented in assembler.
Does any body tried to convert it to C code?
  • There are more efficient ways, just scary you can't figure it out,
    u32 revbit(u32 data)
      int i;
      u32 rev = 0;
      for(i=0; i<32; i++)
        rev |= ((data >> i) & 1) << (31 - i);
      return rev;
  • Thanks for reply but it's not the answer to my question.
    The mentioned file contains arm_bitreversal_32 function
    that takes array of data to be reversed, the length of predefined bit reversal table and bit
    reversal table itself. As as result it should return input array in "normal" order.
    For me the assembler code is not trivial. So I asked if somebody converted arm_bitreversal_32 function in C code or other human readable format?
  • So Clive One supplied you with a function to reverse the bits in a 32 bit word and made a comment "just scary you can't figure it out".
    It now seems you can't figure out how to take that simple function and iterate through a given array of data.
    He's right. It really is scary.
  • Why are you scary just look in source code of arm_bitreversal_32 function from CMSIS DSP
    library and realize that your comments are irrelevant?
  • void arm_bitreversal_32(uint32_t *pSrc, const uint16_t bitRevLen, const uint16_t *pBitRevTab)
      uint32_t r3 = (bitRevLen + 1) / 2;
      uint32_t *r2, *r6;
      uint32_t r4, r5;
      while(r3--)
        r2 = (uint32_t *)((uint32_t)pSrc + pBitRevTab[0]);
        r6 = (uint32_t *)((uint32_t)pSrc + pBitRevTab[1]);
        r5 = r2[0];
        r4 = r6[0];
        r6[0] = r5;
        r2[0] = r4;
        r5 = r2[1];
        r4 = r6[1];
        r6[1] = r5;
        r2[1] = r4;
        pBitRevTab += 2;
  • But the question here - is there any part of that little C function that you are not able to understand and write yourself?
    Because if that is so, then you might actually have needed to spend the time fighting this problem until you learned how to do. Why take a taxi the whole life just to avoid the time to take a drivers license?
    In the end, the only way to learn is to do things that are are hard - you don't build muscles by lifting balloons filled with helium. The brain needs challenges - and it is still a quite reasonable challenge to figure out how to write a loop that iterates through an array of data and through table-lookup bit-reverses data. But it will forever stay a challenge without own work.
