Memory coruption when compiler optimization is on
Working with a Freescale Kinetis K60. When file optimization is set at level 1. Optimize for time is on. Cross-module optimization is off. We see a RAM variable that gets corupted. This variable is passed as an argument to a function. When the function returns the parameter has changed unexpectedly. Please note this parameter is not a pointer. This does not happen when optimization is off. Here is the code:
    AoVal = (uint16_t) par1;
    if (LimitAoSet(Console, AoVal)) {         // AoVal is not changed here
      Ux_putline(Console, "AO1 set ");
      Ux_putdec2ctz(Console, 2, (int)AoVal);  // AoVal gets corrupted here
      SetAo1(AoVal); }
Why does this happen?
  • Who knows?
    You'll need to expand what you're looking at.
    I'd start by looking at what the Ux_putxxx() functions are doing, and make sure the statics/heap/stack are not colliding. Then I'd look at the generated code. Make sure ABI rules are followed.
    Compiler/optimization errors do occasionally occur, but more usually it high-lights poor coding because it's less tolerant. Keil is significantly more solid than GNU/GCC.
  • What type is your variable?
    For some reason, it feels like it might be the type cast that trigs something unexpected.
    Have you looked at the disassembled processor instructions?
  • AoVal is a uint16_t type variable. The Ux_put... functions read AoVal and transmits it's value
    in ascii format on a UART. Nothing special there.
    The (int)conversion is an experiment. Without the (int) conversion the result is the same.
    The coruption of AoVal affects the LSB only. It is set to 0x00. The MSB of AoVal does not change.
    I will compare and verify the assembled results and post my findings here.
  • Is Ux_putdec2ctz() a function, or a #define'd macro?
    And what does the prototype look like?
  • Ux_putdec2ctz is not a macro. It is a function. The prototype:
    uint8_t Ux_putdec2ctz (uint8_t comport, uint8_t dotpos, int c);
    I did increase the heapsize, the rtx stack and the task specific stacksize.
    This did not make a difference so i guess i ruled out that one.
    The only way to avoid the problem is to compile in optimization level 0 (-O0).
    When set to optimization level 'default' the problem persists.
    Here are the disassembly listings with optimization and without optimization.
    There are branches to other code so i'm not sure the clue is to be found here.
    Disassembly listing with optimization Level 1:
      1360:     case 100:         /* set ao1, analog1 output (10uA steps) */
    0x0000EFC0 F7FFBB2B  B.W           0x0000E61A
      1361:     AoVal = (uint16_t) par1;
    0x0000EFC4 B2AC      UXTH          r4,r5
      1362:     if (LimitAoSet(ConsPort, AoVal)) {
    0x0000EFC6 4621      MOV           r1,r4
    0x0000EFC8 982D      LDR           r0,[sp,#0xB4]
    0x0000EFCA F7FAFC17  BL.W          LimitAoSet (0x000097FC)
    0x0000EFCE 2800      CMP           r0,#0x00
    0x0000EFD0 F43FAB23  BEQ.W         0x0000E61A
      1363:       Ux_putline(ConsPort, "AO1 set ");
    0x0000EFD4 A15F      ADR           r1,{pc}+4  ; @0x0000F154
    0x0000EFD6 982D      LDR           r0,[sp,#0xB4]
    0x0000EFD8 F7F9FD3E  BL.W          Ux_putline (0x00008A58)
      1364:       Ux_putdec2ctz(Console, 2, AoVal);
    0x0000EFDC 4826      LDR           r0,[pc,#152]  ; @0x0000F078
    0x0000EFDE 4622      MOV           r2,r4
    0x0000EFE0 2102      MOVS          r1,#0x02
    0x0000EFE2 7800      LDRB          r0,[r0,#0x00]
    0x0000EFE4 F7FAFBB0  BL.W          Ux_putdec2ctz (0x00009748)
      1365:       Ux_putline_eol(ConsPort, " mA");
    0x0000EFE8 A15D      ADR           r1,{pc}+4  ; @0x0000F160
    0x0000EFEA 982D      LDR           r0,[sp,#0xB4]
    0x0000EFEC F7F9FD94  BL.W          Ux_putline_eol (0x00008B18)
      1366:       SetAo1(AoVal); }
      1367:     break;
    Disassembly listing with optimization level 0:
    0x00011C14 E57D      B             0x00011712
    0x00011C16 9834      LDR           r0,[sp,#0xD0]
    0x00011C18 B280      UXTH          r0,r0
    0x00011C1A 902B      STR           r0,[sp,#0xAC]
    0x00011C1C 992B      LDR           r1,[sp,#0xAC]
    0x00011C1E 9833      LDR           r0,[sp,#0xCC]
    0x00011C20 F7F9FF08  BL.W          LimitAoSet (0x0000BA34)
    0x00011C24 B180      CBZ           r0,0x00011C48
    0x00011C26 A1CB      ADR           r1,{pc}+2  ; @0x00011F54
    0x00011C28 9833      LDR           r0,[sp,#0xCC]
    0x00011C2A F7F8FE09  BL.W          Ux_putline (0x0000A840)
    0x00011C2E 2102      MOVS          r1,#0x02
    0x00011C30 48CB      LDR           r0,[pc,#812]  ; @0x00011F60
    0x00011C32 7800      LDRB          r0,[r0,#0x00]
    0x00011C34 9A2B      LDR           r2,[sp,#0xAC]
    0x00011C36 F7F9FDAD  BL.W          Ux_putdec2ctz (0x0000B794)
    0x00011C3A A1CA      ADR           r1,{pc}+2  ; @0x00011F64
    0x00011C3C 9833      LDR           r0,[sp,#0xCC]
    0x00011C3E F7F8FE60  BL.W          Ux_putline_eol (0x0000A902)
    0x00011C42 982B      LDR           r0,[sp,#0xAC]
    0x00011C44 F007F870  BL.W          SetAo1 (0x00018D28)
      1367:     break;
  • Would kind of suggest that R4 is getting corrupted by Ux_putline(), you could step over that call in the debugger and see if R4 changes. Then you'd drill into the code for Ux_putline() to understand why that violates the ABI
    R4 holds AoVal in the optimized version, on the non-opt version it's held on the stack.
