hi, i m facing one peculiar problem in timer 1 interrupt in Atmel 89c52. Using interrupt, I am generating a pulse at regular intervals. If I watch the pulses continuously in oscilloscope,sometimes pulse width is varying. Can anyone help me in this regards. I attached the code here. main() { /* Assume proper time settings here */ ---- ---- while(1) { P0=0; overflow_count=0; while(overflow_count <=4000); P0=1; overflow_count=0; while(overflow_count <=4000); } } void timer1 interrupt 3 { overflow_count++; } Assume no syntax error or logical errors in the code. regards, sara
Aside from latency, you have the problem that the ISR can increment overflow_count while main() is comparing or resetting it. In this case you would be better testing and resetting overflow_count and toggling the port pin in the ISR. You'll still get a little variation in pulse width (which will be worse if you have other interrupts of the same or higher priority active) but hopefully it'll be within your tolerance. Stefan
Sure, it is due latency - you should move a toggle command into ISR. But the best way for generate 1/2 duty cycle pulse is usage Timer2 in in Clock-out Mode. By this way, the pulse width has never been varyed - neither by latency nor by software. Good days!
