To check flow of RTOS Tiny execution.
Hi All
On test board:Leds(2 nos) --> P1.1,P1.2
Buzzer --> P1.3
In Task0:Task1 and Task2 are created.
In Task1:
led1 = On,led2 = off --> delay() --> led1 = Off,led2=On.
In Task2:
buzzer = On --> delay() --> buzzer = off.
Serial port,Timers,Interrupts not initialised.
No external RAM connected(only one int var used in code).
After running this program on 89C51RD2 nothing was working.
what might be the problem ?
Do i have to initialise Timer,interrupts ?
is this problem related to delay routines ?
can any body suggest how can i check flow of RTOS program execution
by using above on board resources ?
regards
Naresh
