I'm hoping to use both of the following emulators for my development. Will I be able to source level debug from keil with them? PDS900 - LPC921 PDS51-Mk2 - P89C66X Also will the regular DK51\PK51 tool suites support the LPC921? Thanks much John
Will I be able to source level debug from keil with them? I assume you can, previous Philips ICEs I have used could. This is really a question for Philips, rather than for Keil. Erik
Philips says yes, but I'm a little leary of LPC900 series emulator since it's not officially listed from Keil. Just want to make absolutly sure from Keils end before I go and spend $6000 if they have tested it or not. They also offer I believe a "cut-down" version of PK51 that just does the LPC900 series. Just want to make sure their regular version includes LPC900 support. John
John, Although I haven't used the PDS900 or PDS51 emulators, I'm pretty certain that they will work with the Keil tools. I'm CERTAIN that Philips have the OMF specifications and I'm certain that other tools work with OMF51 and OMF2. If Philips says these emulators will work, then I'm sure they will. The ONLY strange thing on the emulator might be how code banking is supported (every emulator does this differently). As far as the LPC900 devices, they are supported by the full tools. We also have an evaluation toolset for the LPC900. More information is available at: http://www.keil.com/lpc/lpc900_overview.asp. Jon
