I write function, which recieve 4 characters from serial port with _getkey() function. It waits until all characters does not come. I need to exit from recieving if characters does not come for long time (about 1 sec.). Please write example. Thanks Martin Pokorny
You just need to check a timer overflow flag along with the serial interrupt flag in your loop. _getkey() blocks until a character is received, so you need a different loop polling both possible event sources. Something like:
// set up timer 0 // start timer 0 for 1 second charsRx = 0; while (!TF0 && (charsRx < 4)) { if (RI) { // got a character, fetch it buffer[charsRx++] = _getkey(); } }
