Assembler: ---------- CCAPM1 DATA 0C3h ANL CCAPM1, #00dh C equivalent ???? ----------------- sfr ccapm1 = 0xc3; ccapm1 = ccapm1 & ~(0x0d); or ccapm1 = ccapm1 & 0x0d; or ccapm1 = ccapm1 && 0x0d; Can some one shed a light on the correct interpretation?? Thanks.
"Can some one shed a light on the correct interpretation" What you need is a 'C' textbook!
Always a good idea to have a language reference handy. I imagine you can find a tutorial on the web with a bit of Googling. Here's an online reference: http://www-ccs.ucsd.edu/c/ but it's just that -- a reference, and so may be short on explanation. C has both "bitwise" and "logical" AND and OR operators. The bitwise operators act on each bit in a type independently. The logical operators interpret the operands as Boolean values (0 is false, non-zero is true, which is 1) and then produce a result. To set and clear bits, you generally want the bitwise operators, which are the single-character version ('&' instead of '&&'). ccapm1 = ccapm1 & 0x0d; is the match for ANL CCAPM1, #0dH It performs a bitwise AND of the value in ccamp1 with 0x0d, and then stores the result back into ccapm1. ccapm1 = ccapm1 && 0x0d; will probably not do what you want. If ccapm1 is non-zero, then the result of the logical expression is 1, which will be assigned to ccapm1. If ccapm1 is zero, it will remain zero. ~ is the bitwise NOT operator. It inverts all the bits in the operand. So ccapm1 = ccapm1 & ~0x0d; is the same as ccapm1 = ccapm1 & 0xf2; Since using a variable in this sort of expression and then reassigning the result is such a common thing to do, C provides a shorthand notation. ccapm1 &= 0x0d; means exactly the same thing as ccapm1 = ccapm1 & 0x0d; The usual idioms for setting and clearing bits are thus: var |= mask; // set 1 bits of mask in var var &= ~mask; // clr 1 bits in mask from var
