Setting S0RIR
After receiving a command on the serial port I want to disable all interrupts and then wait for the serial port to receive a byte. The following code shows what I am doing.
IEN = 0 ;
_nop_() ;
_nop_() ;
while( !S0RIR ) ;
rxbyte = ( uint8_t ) S0TBUF ;
S0RIR = 0 ;
It appears that I never pass the while loop. Does disabling the serial rx interrupt stop S0RIR being set ? Any ideas ?
I am using a ST10F168.
Cheers
Elliot
  • Hi Elliot,
    Doesn't seem like there is anything wrong with that piece of code. A byte arrives - S0RIR gets set, regardless of IEN or S0RIE. That's provided that ASC0 control register holds the right value. For example, here is an extract from the microcontroller manual:
    S0REN
    Receiver Enable Bit
    0: Receiver disabled
    1: Receiver enabled
    (Reset by hardware after reception of byte in synchronous mode)
    Another thing: how do you know that you reach the loop? Do you have an in-circuit debugger set up?
    - mike
  • The only debugging I can do is with a serial coms program that lets me look at values in nvSRAM. I set a value before the
    while(!S0RIR ) ;
    line and then set it to a different value afterwards. Unfortunately this is the only technique I can use other than the uVision simulator where everything works fine. It appears for some reason that the flag is not set for some reason.
    Cheers
    Elliot
  • It appears for some reason that the flag is not set
    Not necessarily so. It is possible that the program crashes for a different reason before the flag is set (while in the loop or not even reaching the loop) - NMI or watchdog or whatever. It's all speculation, though, not having seen the full source code.
    - mike
  • Have you checked the serial line with an oscilloscope?
    Do you use the Debugger (which also uses S0)?
  • I have found a solution to my problem. The receive code needs to be as follows for it to work correctly.
    while( !S0RIR & !S0EIR ) ;
    rx_char = ( uint8_t ) S0RBUF ;
    S0RIR = 0 ;
    S0EIR = 0 ;
    I thought that the S0EIR flag was set simultaneously with the S0RIR flag from my reading of the manual. This appears not to the case ? Can anyone shed any light on this?
    I set S0CON to 0x90B7.
    Cheers
    Elliot
  • I thought that the S0EIR flag was set simultaneously with the S0RIR flag from my reading of the manual.
    I thought so too. According to the manual, in your piece of code
    should have the save effect as
    while( !S0RIR ) ;
    If it's not the case, it looks like a chip bug to me. But I would investigate that further if I wanted to be sure.
    Anyway, having errors during reception is not a good thing. Besides, I would write
    while( !S0RIR && !S0EIR ) ;
    instead of
    Both should do the same, but the latter can be confusing.
    Regards,
    - mike
  • while( !S0RIR & !S0EIR ) ;
    ... can be confusing.
    And quite probably generates more code if efficiency is a concern. The only time you would want the bitwise-AND versus the logical-AND in this context is when you need the side effects of evaluating the second operand (which is extremely unlikely to be the case here).
  • Hi Again
    This code works at 9600 baud but seems to have problems at higher rates and is contrary to the manual.
    uint8_t GetByte( void )
    	uint8_t rx_char ;
    	while( !S0EIR && !S0RIR ) ;
            S0RIR = 0 ;
    	S0EIR = 0 ;
    	return rx_char ;
    but this code cause a reset
    	uint8_t rx_char ;
    	while( !S0RIR ) ;
            S0RIR = 0 ;
    	return rx_char ;
    I am not using a watchdog and have no interrupts. Has anyone any theories on what might be happening ? This is driving me mad.
    Cheers
    Elliot
  • Well, without an in-circuit debugger you can never be sure what's going on. Besides, hardware problems is always a possibility (floating NMI pin, for example.)
    Set up debugging with Monitor166. Even if there is no external RAM in your target hardware, you should be able to debug small pieces of code with 6Kbyte of XRAM.
    Good luck!
    - mike
  • Servicing my non-running watchdog timer means that the code now works fine.
        while( !S0RIR )
            _srvwdt_() ;
        S0RIR = 0 ;
    Maybe a hardware problem ? Thanks for your help.
    Cheers
    Elliot
  • The watchdog timer is running unless you stop it before an EINIT or SRVWDT instruction.
    Sauli
