hello! i find the problem which i debug my Project with Keil Software(V7.05). it's no Serial 2, can't useing Dual Data Pointers,and can't useing other special features of VERSA1-B(VRS1001-C20B) MCU when i Start Debug my my Project,Although i can select the VERSA1-B(VRS1001-C20B) device in Project -> Option for Target "Target1" ->(device list) ->Goal Semiconductor ->VERSA1-B(VRS1001-C20B). it's looks like the standard 8052 CPU. who could tell me How could i do for useing my VERSA1-B(VRS1001-C20B) MCU's special features ? With best regards ! BTW:The VERSA1-B(VRS1001-C20B) DataSheet at : http://www.goalsemi.com/VERSA1-B_Datasheet.pdf
If you have the full version of software, you should contact Keil support direct. The simulated peripheral support is shown here: http://www.keil.com/dd/chip/3503.htm It only lists one serial port. :-( Perhaps you could find another 2-port variant, and use that for simulation? Otherwise, how about uVision Debug and Signal functions? Failing that, you'll have to write your own peripheral DLLs - there's an App Note about it. Have you asked Goal if they have any suggestions?
first of all , thanks for reply. Can't the evaluation software simulate Goal VERSA1-B(VRS1001-C20B) MCU full features ?!!!
"Can't the evaluation software simulate..." AFAIK, The eval version has the full set of devices - there's no restriction there! I only mentioned if you have the full version as that determines whether you're entitled to support or not! If you have the eval version, it includes a document which details all the limitations - you do need to read it, otherwise you will fall into some traps!
thanks Andrew . Is it means that the man useing eval version is NOT entitled to support ?
If <above viewpoint> then Keil_Software = Feebleness
bit EvalVersionIsNOTEntitled2Support ; while ( ! EvalVersionIsNOTEntitled2Support ) { Keil_Software = Feebleness++ }
"Is it means that the man useing eval version is NOT entitled to support? If <above viewpoint> then Keil_Software = Feebleness" Tursun, Of course you're entitled to support for something free. In fact, I've heard that Keil are now offering to send an engineer out to your site to train you. What's more, to compensate for the inconvenience of being trained they will pay you an hourly rate to learn how to use their excellent product. Their final guarantee is this: if you are not an expert C51 programmer after three months they will apologise, pay you the full cost of their professional development package and throw in a free holiday to boot. I realise this is all still a little tight fisted of them but I'm sure they will be able to improve on this offer over the next few years as more and more Tursuns take advantage of their free support for their free evaluation package. Have a nice day! Stefan
There's a bug in your program:
bit EvalVersionIsNOTEntitled2Support ; while ( ! EvalVersionIsNOTEntitled2Support ) { Keil_Software = Feebleness++ /*** ; goes here ***/ }
Is it means that the man useing eval version is NOT entitled to support ? The following support options are FREE:
