Dear all, For some reason, I need to declare an array like that
#define STRING2_DESCRIPTOR_LENGTH 16 BYTE code product_string_descriptor[] = { STRING2_DESCRIPTOR_LENGTH, 0x03, 'U', 0x00, 'S', 0x00, 'B', 0x00, ' ', 0x00, 'H', 0x00, 'U', 0x00, 'B', 0x00 };
product_string_descriptor: DB end - $ DB 0x03, DB 'U', 0x00 DB 'S', 0x00 DB 'B', 0x00 DB ' ', 0x00 DB 'H', 0x00 DB 'U', 0x00 DB 'B', 0x00 end:
I do not know of a way to do this purely at compile time. Perhaps I'm overlooking something this morning, but this is as close as I got:
typedef struct { U8 length; U8 val; } StrDescHdr; U8 code pstr[] = { 'U', 0, 'S', 0, 'B', 0, ' ', 0, 'H', 0, 'U', 0, 'B', 0}; typedef struct { StrDescHdr Hdr; U8 code* value; } StrDesc; StrDesc code psd = { { sizeof(pstr) + sizeof(StrDesc), 3 }, pstr };
Hi Drew, Thanks for the suggestion of explicitly declare the size. But I think the compiler will not warn me if I have less initializer than the actual size. Most of the compiler will fill the rest of the array with zero. Am I right? Anyway, the compiler will still warn me if I supply more intializer than the actual size. So, I consider it as a better solution than before. Thanks again.
How about this:
BYTE code table[] = ... #define TABLE_LEN (sizeof(table) / sizeof(table[0]))
"I know in assembly, I can do something like..." So why not just do it in assembler, then?! If it's difficult in 'C' but easy in Assembler - surely the choice is obvious!! There is no problem linking 'C' & assembler in a single Project.
Hi Jon, You define TABLE_LEN after table[]. So, I think I can not use it in the initialization of table[]. But even if I define TABLE_LEN in front, I will still get the following warning warning C198: sizeof returns zero
Hi Andy, The reason for me to post this question is that I think if I am able to do it in C, my strength is getting stronger than before. Just like when you are learning Mathematics, will you feel better if you know more than one solution for some questions than the other?
OK, Then what about the following:
#define USB_DESC "\03" "USB HUB" #define USB_DESC_LENGTH (sizeof(USB_DESC) - 1) /*** -1 for null terminator ***/ static unsigned char code product_string_descriptor[] = { USB_DESC_LENGTH, USB_DESC };
