I have: 1. ext_port.a51 file, that contains some variables. 2. ext_port.inc file, that contains some macros, that use variables from ext_port.a51. 3. some files, that use macros from ext_port.inc. In my case I want use EQU to use this variables, but this variables is external and I take error A20. I tried include all this in one file(#include or $include), but in this case debug information is lost. ********************************************* ext_port.a51
?PR?EXT_PORT SEGMENT DATA RSEG ?PR?EXT_PORT public P5Buf public P6Buf P5Buf: DS 1 P6Buf: DS 1
#ifndef _EXT_PORT_INC #define _EXT_PORT_INC #include "set.inc" #define P7A_ADDR f_ad0512 #define P7B_ADDR F_DAT512 #define P7C_ADDR f_ad1512 #define P7CTL_ADDR f_ctl512 #define _P0 0x00 #define _P1 0x10 #define _P2 0x20 #define _P3 0x30 #define _P4 0x40 #define _P5 0x50 #define _P6 0x60 #define _P7A 0x70 #define _P7B 0x71 #define _P7C 0x72 #define _P7CTL 0x73 P_0x00 EQU P0 P_0x10 EQU P1 P_0x20 EQU P2 P_0x30 EQU P3 P_0x40 EQU P4 P_0x50_ADDR EQU P5_HIGH_ADDR P_0x60_ADDR EQU P6_HIGH_ADDR P_0x70_ADDR EQU P7A_ADDR P_0x71_ADDR EQU P7B_ADDR P_0x72_ADDR EQU P7C_ADDR P_0x73_ADDR EQU P7CTL_ADDR ;---------------------------------------------------------------------------- extrn DATA (P5Buf) extrn DATA (P6Buf) P_0x50_Buf EQU P5Buf P_0x60_Buf EQU P6Buf ;---------------------------------------------------------------------------- ; xxx_m - state format is mask ; xxx_c - state is constant ; xxx_sb - state is variable.bit ;---------------------------------------------------------------------------- #define PORTS_ExSpec _P7A, _P7B, _P7C #define PORTS_Ex _P5, _P6 #define PORTS_x _P0, _P1, _P2, _P3, _P4 _PXXX_CALL macro p, pl, fc, ft, prm irp px, <pl> if p == px fc&ft prm endif endm endm ;---------------------------------------------------------------------------- Px_set_c macro p, b, s if s setb p.b else clr p.b endif endm Px_c macro p, b, s Px_set_c P_&p, b, s endm PxEx_select_set_c_m macro paddr, pbuf mov DPTR, #paddr if s orl pbuf, #bm else anl pbuf, #NOT bm endif endm PxEx_c_m macro p, bm, s PxEx_select_set_c_m P_&p&_ADDR, P_&p&_Buf, bm, s mov A, pbuf movx @DPTR, A endm PxEx_c macro p, b, s PxEx_c_m p, (1 SHL b), s endm Px_OUT_BIT_c macro p, b, s _PXXX_CALL p, <PORTS_x>, Px, _c, <p, b, s> _PXXX_CALL p, <PORTS_Ex>, PxEx, _c, <p, b, s> endm ;---------------------------------------------------------------------------- Px_set_sb macro p, b, vp, vb mov A, vp mov C, ACC.vb mov p.b, C endm Px_sb macro p, b, vp, vb Px_set_sb P_&p, b, vp, vb endm PxEx_out_C macro paddr, pbuf, b mov DPTR, #paddr mov A, pbuf mov ACC.b, C mov pbuf, A movx @DPTR, A endm PxEx_sb macro p, b, vp, vb mov A, vp mov C, ACC.vb PxEx_out_C P_&p&_ADDR, P_&p&_Buf, b endm Px_OUT_BIT_sb macro p, b, vp, vb _PXXX_CALL p, <PORTS_x>, Px, _sb, <p, b, vp, vb> _PXXX_CALL p, <PORTS_Ex>, PxEx, _sb, <p, b, vp, vb> endm ;---------------------------------------------------------------------------- Px_OUT_ macro p, v mov P_&p, v endm PxEx_OUT_ macro p, v mov DPTR, #P_&p&_ADDR mov A, v mov P_&p&_Buf, A movx @DPTR, A endm PxExSpec_OUT_ macro p, v mov DPTR, #P_&p&_ADDR mov A, v movx @DPTR, A endm Px_OUT macro p, v _PXXX_CALL p, <PORTS_x>, Px_OUT, _, <p, v> _PXXX_CALL p, <PORTS_Ex>, PxEx_OUT, _, <p, v> _PXXX_CALL p, <PORTS_ExSpec>, PxExSpec_OUT, _, <p, v> endm ;---------------------------------------------------------------------------- #endif
#include "ex_port.inc" Px_OUT _P5, #0
#include "ex_port.inc" Px_OUT _P5, #1
You don't provide any information about where you get that assembler error. In case of doubt, look in the assembler listing. The error message will be in there, too.
+1 2095 extrn DATA (P5Buf) +1 2096 extrn DATA (P6Buf) +1 2097 P_0x50_Buf EQU P5Buf *** _________________________________________________^ *** ERROR #A20 IN 2097 (ext_port.inc, LINE 58): INVALID SIMPLE RELOCATABLE EXPRESSION +1 2098 P_0x60_Buf EQU P6Buf *** _________________________________________________^ *** ERROR #A20 IN 2098 (ext_port.inc, LINE 59): INVALID SIMPLE RELOCATABLE EXPRESSION
Well, the manual states "Segment and external symbols are not allowed in simple relocatable expressions.
Dan Henry Yes, I think that. But I want find way to bypass this problem. One way - include all files in one file: a.a51
#include "ext_port.inc" #include "ext_port.a51" #include "1.a51" #include "2.a51"
You may have to get rid of those EQU, then, and replace them by SET, or #define a macro.
SET same as EQU I can use #define, but it not worked in macro constructions. -----------------------------------
#define P_P5_Buf P5Buf TEST macro px mov P_&px&_Buf, A endm TEST P5
