ulink prob
How did you solve this problem?
How and where to set in utilities?
Kindly reply
  • You're question isn't particularly clear or specific. What problem? What version of Keil?
    To select the ULINK as the debugger for a project, go to the Project Options, select the Debug pane, select the type of debug pod you have, and going into the Settings for it to change those.
  • I am using keil uvision 5 and using stellaris lm4f120H5qr. I have installed all the drivers plus when I am using code composer studio every thing is all right But with Keil my programm successfully built and when comes to download it shows an error that ulink device not found. to be more specific I am using windows 8.
    Kindly help me
  • And you have a U-LINK debug probe? Because I'm reasonably sure Code Composer doesn't use a U-LINK for it's debug connectivity.
    If you don't have a U-LINK probe, it's going to be pretty hard for the Keil uVision to "find" one for you.
    Also make sure you're using a U-LINK II, as the original U-LINK (the one using the Cypress USB chip) has been discontinued for some time.
