Hi all,
I'm using UV5 to communicate by TCP/sockets with a remote PC. I use the BSD_Client exemple and change a few things (GPIO, IP, PORTs) to communicate with my PC program. It work but only for a 30 seconds, after that the communication stop for like 10 seconds and start again...
#include "cmsis_os.h" /* CMSIS RTOS definitions */ #include "rl_net.h" /* Network definitions */ //-------- <<< Use Configuration Wizard in Context Menu >>> ----------------- // <h>Remote IP Address // ==================== // // <o>IP1: Address byte 1 <0-255> // Default: 192 #define IP1 192 // <o>IP2: Address byte 2 <0-255> // Default: 168 #define IP2 168 // <o>IP3: Address byte 3 <0-255> // Default: 0 #define IP3 1 // <o>IP4: Address byte 4 <0-255> // Default: 100 #define IP4 62 // </h> // <o>Remote Port <1-65535> // Do not set number of port too small, // maybe it is already used. // Default: 1001 #define PORT_NUM 5001 // <o>Communication Protocol <0=> Stream (TCP) <1=> Datagram (UDP) // Selecet a protocol for sending data. #define PROTOCOL 0 // <o>LED Blinking speed <1-100> // Blinking speed = SPEED * 100ms // Default: 2 #define SPEED 1 //------------- <<< end of configuration section >>> ----------------------- #define BLINKLED 0x01 /* Command for blink the leds */ #if (PROTOCOL == 0) #define SOCKTYPE SOCK_STREAM #else #define SOCKTYPE SOCK_DGRAM #endif static void Client (void const *arg); osThreadDef(Client, osPriorityRealtime, 2, 0); /*---------------------------------------------------------------------------- Thread 'Client': BSD Client socket process *---------------------------------------------------------------------------*/ static void Client (void const *arg) { SOCKADDR_IN addr; int sock, res; char dbuf[4]; while (1) { sock = socket (AF_INET, SOCKTYPE, IPPROTO_TCP ); addr.sin_port = htons(PORT_NUM); addr.sin_family = PF_INET; addr.sin_addr.s_b1 = IP1; addr.sin_addr.s_b2 = IP2; addr.sin_addr.s_b3 = IP3; addr.sin_addr.s_b4 = IP4; connect (sock, (SOCKADDR *)&addr, sizeof (addr)); while (1) { dbuf[0] = 'O'; dbuf[1] = 'S'; dbuf[2] = 'C'; res = send (sock, (char *)&dbuf, 2, 0); if (res < 0) { break; } osDelay (100 * SPEED); } closesocket (sock); } } /*---------------------------------------------------------------------------- Main Thread 'main': Run Network *---------------------------------------------------------------------------*/ int main (void) { // LED_Initialize (); // init_display (); net_initialize (); // Create networking task osThreadCreate (osThread(Client), NULL); while(1) { net_main (); osThreadYield (); } }
Any ideas about what is happening?
Luis Felipe
