I am new to MCB2140. I want to interface RS232 to MCB140 for serial communication between PC and Board. Below is my code. I searched for manual and gone through the basics for UART initialization. Everything here I did is correct in my knowledge. But I cant receive anything to hyperterminal.What will be the problem??
#include <LPC21xx.H> //Function declaration void init_serial (void); char SendChar (char SDat); void SendDigit(unsigned int dat); void SendString(char *lcd_string); int main(void) { //int j=0; init_serial (); // initialise serial port with 9600bps SendChar ('A'); // transmit char A SendChar ('\n'); // transmit new line character SendString("My first program"); // transmit string SendChar ('\n'); // transmit new line character SendDigit(236); // transmit digit 236 } //Function Definitions void init_serial (void) { /*Initialize Serial Interface */ PINSEL0 = PINSEL0 | 0X00000005; /* Enable RxD0 and TxD0 */ U0LCR = 0X83; /*8 bits, no Parity, 1 Stop bit */ U0DLL = 98; /* 9600bps baud rate */ U0LCR = 0X03; /* DLAB = 0 */ } int GetChar (void) //for later use { /* Read character from Serial Port */ while (!(U0LSR & 0x01)); return (U0RBR); } char SendChar (char SDat) { /* Write character to Serial Port */ while (!(U0LSR & 0x20)); return (U0THR = SDat); } void SendString(char *lcd_string) { while (*lcd_string) { SendChar(*lcd_string++); } } void SendDigit(unsigned int dat) { unsigned int temp,i=0, buf[10]; while(dat>=10) { buf[i]=dat%10; dat=dat/10; i++; } buf[i]=dat; for(temp=0;temp<=i;temp++) { SendChar(buf[i-temp]+'0'); } }
Don't exit main()
Put a scope on the pins, and check the bit timing with a scope while sending a 'U' character in a loop.
There were some UART1 examples in serial.c files under the board examples.
Thanks for the reply... Don't exit main() means you are saying to use infinitie loop right[while(1)]. Also how to put scope on the pins??
