Hi when trying to download flash to STM32L152 using Keil and ST-Link V2 debugger from SW port, I see "Internal command Error" boot and reset dose not help. is there any way to get rid of this problem?
It's typical of when you put the processor in a low-power state or other break the debugging connection by what you've done with your code.
Pull BOOT0 High, or select "Connect Under Reset" with respect to how the debugger controls the chip when it first connects.
I pulled up BOOT0 but see same error. I tried "connect under reset" and again same error "internal command error"
And you're using SWD mode, and not JTAG?
What were you doing immediately before it failed? What changed in the software or the system?
Yes SWD. Last time I programmed it with a program generated by cube32mx in low power 32Khz. Just now I tried sth and problem solved. I pushed reset button and same time clicked the flash download icon and chip got programmed.
Does you board have NRST attached?
Yes NRST is pulled up to VCC and there is a push button connecting NRST to GND.
I was thinking to the debug interface, but never mind... In that the option to "connect-under-reset" could actually achieve that.
