Hi there. From unknown reason, using the eclipse plugin from Keil folder makes the debugger to work extremely slow. When I use the debugger without the eclipse the response is great. Any idea why?
Using Mars version 4.5.2 32Bit. Thanks, Ravid.
Still waiting.
Then, I would say you could try using µVision directly instead of eclipse...
The question is do I have a malfunction in the eclipse or the plugin is intended to work this way?
