I use an Arm Cortex M0 plus Controller and want to migrate a Project from Simplicity IDE to Keil IDE. But now there is always the error mentioned in the summary. I don't know why this error occur do I have to include other files or something like this? In Simplicity Studio all worked fine.
Nice regards
Found it I had to add the right libs in the Manage-Runtime-Environment ;)
Nice Day
hello i am facing the same problem how can solved this problem
If it's the same problem, then the solution will be the same - as given in the four-year-old post you replied to!
Otherwise, start a new thread with a full description of what you have, what you are doing, and the full error message(s) you are receiving.
Is this your problem:
https://community.arm.com/developer/tools-software/tools/f/armds-forum/45405/getting-errors-after-including-arm_math-h
Clearly an entirely different issue!
