Hi there. This thread is related to the RL-TCPnet component using the MCB4300 board.
I'm trying to connect a socket using the tcp_connect function to an external server.
I can connect the socket to internal servers (by internal I mean running in the same network), but when it comes to external servers it just aborts the connection. In other words, the callback function to the tcp_connect function just gets the TCP_EVT_ABORT as an event.
Here's a snippet of the code I'm using:
U8 tcp_soc; U16 tcp_callback (U8 soc, U8 event, U8 *ptr, U16 par) { switch (event) { case TCP_EVT_CONREQ: // This event just comes up on internal connections return (1); case TCP_EVT_ABORT: // When trying to connect to external servers, I just get the connection ABORTED break; case TCP_EVT_CONNECT: break; case TCP_EVT_CLOSE: break; case TCP_EVT_ACK: break; case TCP_EVT_DATA: break; } return (0); } void main (void) { init (); init_TcpNet (); tcp_soc = tcp_get_socket (TCP_TYPE_CLIENT|TCP_TYPE_KEEP_ALIVE , 0 , 10000 , tcpCallback); while (1) main_TcpNet (); }
Does anyone have any clue about what is going on?
