interface eeprom AT24C32 with 89S52
HI all,
i need a small help from you all....
i am trying to interface AT24C32 eeprom with 89S52.
my problem is it works perfectly with proteus stimultion but when i tried to built the circuit it give me an error...
code...
Code:
#include<reg51.h>
#include<stdio.h>
#include<intrins.h>   //For using [_nop_()]
sbit sda=P1^7;
sbit scl=P1^6;
sbit buz=P3^7;
bit ack;
void save();
void read();
void msdelay(unsigned int value)  ;
unsigned char reead,write,write2,i,j;
unsigned int temp;
unsigned char userid[7]={"444444"};
unsigned char chanuser[7]={"000000"};
void aknowledge()         //acknowledge condition
        scl=1;
        _nop_();
        _nop_();
        scl=0;
void start()            //start condition
        sda=1;
        scl=1;
        _nop_();         //No operation
        _nop_();
        sda=0;
        scl=0;
void stop()                     //stop condition
        sda=0;
        scl=1;
        _nop_();
        _nop_();
        sda=1;
        scl=0;
void send_byte(unsigned char value)     //send byte serially
        unsigned int i;
        unsigned char send;
        send=value;
        for(i=0;i<8;i++)
                sda=send/128;           //extracting MSB
                send=send<<1;             //shiftng left
                scl=1;
                _nop_();
                _nop_();
                scl=0;
   ack=sda;             //reading acknowledge
   sda=0;
unsigned char read_byte()       //reading from EEPROM serially
        unsigned int i;
        sda=1;
        reead=0;
        for(i=0;i<8;i++)
                reead=reead<<1;
                scl=1;
                _nop_();
                _nop_();
                if(sda==1)
                        reead++;
                scl=0;
        sda=0;
        return reead;   //Returns 8 bit data here
void save()             //save in EEPROM
    start();
        send_byte(0xA0);        //device address
        aknowledge();
        send_byte(0x00);        //word address, Page Numbers
        aknowledge();
        send_byte(userid[0]);
        aknowledge();
        send_byte(userid[1]);
        aknowledge();
        send_byte(userid[2]);
        aknowledge();
        send_byte(userid[3]);
        aknowledge();
        send_byte(userid[4]);           //send data
        aknowledge();
        send_byte(userid[5]);   //send data
        aknowledge();
        stop();
void Read()
        start();
        send_byte(0xA0);
        aknowledge();
        send_byte(0x00);
        aknowledge();
        start();
        send_byte(0xA1);                 //device address
        aknowledge();
        chanuser[0]=read_byte();
        aknowledge();
        chanuser[1]=read_byte();
        aknowledge();
        chanuser[2]=read_byte();
        aknowledge();
        chanuser[3]=read_byte();
        aknowledge();
        chanuser[4]=read_byte();
        aknowledge();
        chanuser[5]=read_byte();
        aknowledge();
        stop();
void main()
  save();
  msdelay(1000);
  read();
  if(chanuser[i]=='4')
  buz=0;
  msdelay(8000);
  buz=1;
  else
  buz=0;
  msdelay(400);
  buz=1;
  msdelay(400);
  buz=0;
  msdelay(400);
  buz=1;
  msdelay(400);
  buz=0;
  msdelay(400);
  buz=1;
  msdelay(400);
  buz=0;
  msdelay(400);
  buz=1;
  msdelay(400);
}//Main Ends Here
 unsigned int i,j;
 for(i=0;i<value;i++)
 for(j=0;j<100;j++);
explaining the code...
initailly it save the data's from userid to eeprom and then after a delay(1000) it again reads the data's from eerpom and saves it to chanuser.
in main() program it checks if the data's of chanuser are as same as userid then LED lights up and if the data's are not as same as userid it starts blinking.
but here as u can see the data's of userid and chanuser are same but still it blinks in my circuit. but works well with proteus stimulation.
it does not works well with my circuit means eeprom is not working well...
can anybody please help me out of this...
  • i need a small help from you all....
    first help do not use the C251 tools the chip is C51.
    well, maybe you are
    the differences between simulation and real life are
    1) hardware (do you have pullups in the lines?)(other things?)
    2) timing, the simulator does not give a s... about timing
    these are the main differences
  • A very early step when software doesn't work would normally be to debug.
    And debugging is the task of figuring out the difference between what is happening and what was assumed to happen.
    You don't seem to have done any comparison between plan and reality.
