Hello, I'm trying to resolve a hostname address by using the function get_host_by_name() but I have a strange behavior when I call this function.
At first, I get an error DNS_ERROR_BUSY. And then I get a trace from the callback with the resolved IP address.
It's the only call to this function in the program, why the DNS client would be busy ?
Here the code of my program :
static void dns_cbfunc(u8 in_u8_event, u8 *pu8_ip) { switch(in_u8_event) { case DNS_EVT_SUCCESS: printf("IP resolved : %d.%d.%d.%d", pu8_ip[0], pu8_ip[1], pu8_ip[2], pu8_ip[3]); break; case DNS_EVT_NONAME: printf("Hostname unknown"); break; case DNS_EVT_TIMEOUT: printf("DNS resolution timeout"); break; case DNS_EVT_ERROR: printf("Error during DNS resolution"); break; default: break; } }
u8 u8_res = get_host_by_name((u8 *)au8_hostaddr, dns_cbfunc); switch (res) { case DNS_RES_OK: printf("DNS resolution success"); break; case DNS_ERROR_BUSY: printf("DNS Resolver is still busy. Request ignored.\n"); break; case DNS_ERROR_LABEL: printf("Host name label too long or contains invalid characters.\n"); break; case DNS_ERROR_NAME: printf("Host name too long or domain missing.\n"); break; case DNS_ERROR_NOSRV: printf("DNS Server IP address not specified.\n"); break; case DNS_ERROR_UDPSEND: printf("UDP send frame error.\n"); break; default: break; }
Hi Christopher LE MEHAUTEDid you solve this problem ?Regards
You realise that the question is over 4 years old:
