How to solve this problem and how did I got into this problem ?
I have used Silabs F930 and Silabs IDE for projects, and Linker gives me this error and it has to do something about the memory mapping and space. How to dig into the source of this problem ? Internet is full of instructions and examples but nothing is clear to me what is happening and how this can be solved. This happens now when code size had increased over a certain point. What kind of settings I should change or command options to solve the problem ? The error message comes in this form: xxxx.obj >> SEGMENT: ABSOLUTE OFFSET: 0023H
Program Size: data=20.0 xdata=0 code=2397 LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 1 ERROR(S) Download cancelled.
Linker BL51.EXE and Compiler C51.EXE
Compiler options are: DB OE BR INCDIR(C:\SiLabs\MCU\Inc) LC ROM(Small) Linker options are: RS(256) PL(68) PW(78) CO(7000)
Thanks.
