Sir
I want to rotate stepper motor at 24 degree after every 15 second. I am using AT89C51 micro-controller, so can you help me out in programming in c programming language.
I am confused in how to convert entire 360 degree circle into 15 steps of every 24 degree and for accurate stepping should I use gear box or not ?
I want to know that how to apply high bit sequence to each winding from micro-controller.
