i m trying to use Mil-Std-1553 B for bulk data transfer. for this i am trying to use circular buffer. can any give me code for circular buffer programming.
thanx rishu
Perhaps you should review how Circular Buffers (Ring/FIFO) are implemented, and then figure out how, and on what, your 1553B bus is implemented.
Discuss this with your project supervisor, and if you have enough training and expertise to perform the task.
If you need to out-source the work, consider a contractor/consultant.
www.lmgtfy.com www.lmgtfy.com
