Hi, I'm using CYGNAL F020 at 22118400 Hz, I would like to know if Keil has a Delay function ?, I can't find it. Thank you,
Look at App Note 105 - it shows how to implement a periodic interrupt and delay routine for the 8051 micros. Might give you some ideas on how to do it for your processor
I posted a reply to your original post in the Cygnal forum about an hour before you posted your question here. Did my suggestion not work? http://www.cygnal.org/ubb/Forum1/HTML/000570.html Jon
