Hi all, I have a PK51 Professional Developers Kit version 6.14. When I build the target, it gives me the following error:
****************************************************************************** * RESTRICTED VERSION WITH 1000H BYTE CODE SIZE LIMIT; USED: 1A27H BYTE (163%)* ****************************************************************************** LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S) *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: C:\KEIL\C51\LIB\C51S.LIB (-----) LIMIT: 1000H BYTES
When you installed it - did you at some point enter your product serial code? Also, do you have a dongle fitted to the back of the machine? In this case, is anything elese connected to the parallel port? If so, try having just the dongle connected alone. Yours, Richard.
There's a utility on this site to test your dongle. Have you tried it?
Make sure that all modules are compiled with the unrestricted compiler. If any modules are compiled with the evaluation compiler, you may receive this message. Jon
