Data Too Large
Can some one tell me how to solve the following problem:
When try to compile my code I receive the message: DATA Segment Too Large.
I dont know if its a porblem of the SE - uVision2 or of I making any mistake.
Amilcar
  • What memory model are you using, and how much data (data, idata, pdata, xdata) do you have declared?
  • Hi, This is you are utilized more than teh available memory.
    In 8051 only 128Byte is direct addressible,
    Some MCU have 256Byte RAm , So you must use
    Byte idata variable to shift this data into idata location , some may have more tahn 256Byte the you use xdata to shift the loaction .
    If you writing a program in C then no problem but if you write in assembly tehn you have to take special care to move your varibel.
