What is the procedure to handle GPT 3 timer interrupt in C165 Utah. I could run the timer get th exact interval programmed on watching the bit T3OTL.
Dear All, I found the problem in handling the T3 interrupt. The problem was i had not set the IEN bit in PSW. There is no document showing the global interrupt enabling procedure in the interrupt section. Rgards, Anil Patil
