I'm tring to create a conditional address statement in my start167.a66. The goal is to be able to use the same start up file with different uv2 targets. one target would be stand-alone and the other target needs to coexist with a bootloader ROM. (The programming tools I have available can only program CS0 ) I tried to create a block using the if/else statement but found out the hard way that the last/latest %Define statement will over ride any previous ones.
; BUSCON2/ADDRSEL2 ; --- Set BUSCON2 = 1 to initialize the BUSCON2/ADDRSEL2 registers $SET (BUSCON2 = 1) ; Uv2/Dave ;$IF (I_USE_CS0 = 1) ; pick you chip %DEFINE(ADDRESS2) (80000H) ; 0x80000 clears the 1'st ROM by 2 times (8*64K)->2x256 %DEFINE(RANGE2) (256K) ; (this setsup a mask for start address as well as size $ELSE ;][ App Programs are to run out of the second ROM and expect intr table @0 %DEFINE(ADDRESS2) (00000H) ; MUST BE SET TO 0! or no intrupts will work %DEFINE(RANGE2) (256K) ; only limited by $ENDIF ; ] of changed chip config
I'm using similar. One UV2 target for embedded ROM compilation, and another one for Monitor debug using the same startup.a66. Don't apply conditonal compilation at the %define but at the init of the ADDSEL (the last %define always win !)(bug sent to KEIL few months ago) Here is my code :
; --- Set BUSCON1 = 1 to initialize the BUSCON1/ADDRSEL1 registers $SET (BUSCON1 = 1) ; Define the start address and the address range of Chip Select 1 (CS1#) ; This values are used to set the ADDRSEL1 register %DEFINE (ADDRESS1_NORMAL) (0100000H) ; normal %DEFINE (ADDRESS1_MONITEUR) (0000000H) ; moniteur %DEFINE (RANGE1) (1024K) ../.. $IF (BUSCON1 = 1) BCON1 SET (_MTTC1 << 5) OR (_RWDC1 << 4) BCON1 SET BCON1 OR ((NOT _MCTC1) AND 0FH) BCON1 SET BCON1 AND (NOT (_RDYEN1 << 3)) BCON1 SET BCON1 OR (_RDY_AS1 << 3) OR (_BTYP1 << 6) BCON1 SET BCON1 OR (_ALECTL1 << 9) OR (_BUSACT1 << 10) BCON1 SET BCON1 OR (_RDYEN1 << 12) OR (_CSREN1 << 14) BCON1 SET BCON1 OR (_CSWEN1 << 15) $IF NOT MONITOR %ADDR (ADDR1,%ADDRESS1_NORMAL,%RANGE1) $ELSE %ADDR (ADDR1,%ADDRESS1_MONITEUR,%RANGE1) $ENDIF MOV ADDRSEL1,#ADDR1 MOV BUSCON1,#BCON1 $ENDIF
Thank you DUPLAY gilles Your solution works great! For any beginner carousing these messages: The monitor has its own "start167.a66" file which executes an EINIT after configuring whatever it needs. If you include your own startup file and run it with the monitor, certain instructions will not have any effect like modifying the watchdog or CLOCKOUT (CLKEN) settings. The address configuration registers, (and BUSCONx reg), however, can be modified (as long as you not running out of them).
