Using the SRC directive.
hmm...probably the question sounds stupid.....but I'm facing such a problem...
Does the addition of a bit variable(local to a function) to a file with SRC directive cause any problems? (bit variables in my program is within limits(<128))
I ask this because my function behaves weirdly if the bit variable is removed and works fine if I simply add the bit variable without using it in the function!!!
warm regards,
Sandy
