serial and timer problem
hi,
The soft is composed with
• One interrupt timer
• One serial interrupt
If we use at the same time the serial interrupt and the timer interrupt, the string transfert is not regular, she was composed by random wrong value like ';' '&' or another character.
If we remove the timer, the transfert is correct.
#define MAIN
#include "external.h"
void timer (void)
TMOD &= 0xF0;
TMOD |= 0x01;
TL0 = 0x00;
TH0 = 0x00;
ET0 = 1;
TR0 = 1;
void serial_interrup(void) interrupt 4
{ idata unsigned char caractere;
ES0 = 0;
if (RI)
{ caractere = SBUF0;
RI = 0;
ES0 = 1;
void Timer_0(void) interrupt 3
ET0 = 0;
TL0 = 0xED;
TH0 = 0xCB;
ET0 = 1;
void config_Rs232(void)///////// 19200 bauds ///////////
{ ES0=0;
SCON0 = 0x50;
RCAP2H = 0xFF; // Baud H BAUDTAB_H[]
RCAP2L = 0xE5; // Baud L BAUDTAB_L[]
TI = 0;
ES0 = 1;
void main(void)
unsigned char k;
Poids=0;
IE = 0x00;
timer();
config_Rs232();
EA=1;
while(1)
{ ++Poids;
sprintf( PdsAff, "%ld",Poids);
Chaine[0]='0';//CONFIG;
Chaine[1]=' ';//ReadConfig;
Chaine[2]=PdsAff[0];
Chaine[3]=PdsAff[1];
Chaine[4]=PdsAff[2];
Chaine[5]=PdsAff[3];
Chaine[6]=PdsAff[4];
Chaine[7]=PdsAff[5];
Chaine[8]=PdsAff[6];
Chaine[9]=PdsAff[7];
Chaine[10]=PdsAff[8];
Chaine[11]=PdsAff[9];
Chaine[12]=PdsAff[10];
Chaine[13]=PdsAff[11];
Chaine[14]=0x0A;
for(k=0;k<15;k++)
{ ES0=0;
SBUF0=Chaine[k];
while(TI!=1);
TI=0;
ES0=1;
