I want to output to a file, a log of timing & variable information that I could then import into a spreadsheet where I can more easily visualize its operation. I need to output the value of a few different variables at a specific point in an interrupt sequence, and also need to output the "states" clock count or "sec" debug timer data. Thanks Scott Kelley
Are you talking about your target hardware, or the uVision simulator?
Sorry about that - I am talking about collecting data from the uVision simulation. Thanks, Scott
Some samples how to pick data from uVision were on http://www.c51.de/c51.de/Dateien/uVision2DLLs.php3?Spr=EN -PA
I don't see anything there about saving data to a file . . . do you know anything more specific as to what I am looking for?
well, this is not exactly what you need, just the idea how you can use extension DLLs... In Keil App. note 154 you can find documentation and sample source. For instance, define a custom SFR, then log writes to it into a file, or even drive Excel directly thru it's automation interface. Also you can define a signal f() or breakpoint function that prints values, redirect uVision log to file, then filter that file with some program...
we too have the same problem.we need to output the performance analyser results(execution times) to a file.please suggest some solution
