debug - break on watchdog reset?
I'm using 87C51RA+ which includes watchdog timer on the PCA Module 4
I have been trying to set up a conditional break using the uVision2 Debug|Breakpoints dialog box.
MAT4 and TOG4 are both set in the watchdog startup code with the following:
CCAPM4 = 0x4C;
From what I understand, CCF4 should toggle high when the watchdog is activated, but the following breakpoint does not work during debug:
CCF4 == 1
Other experimenting has given similar results, I tried:
CCAP4H == CH & CCAP4L == CL
with the same results, the break does not occur, yet the watchdog does kick off and reset occurs.
Am I missing something? Any other tricks to getting a breakpoint to work on the watchdog?
Thanks,
Scott Kelley
